13 | |
11 | |
3 | |
3 | |
2 |
From the 2014 upgrade notes:
Reviewing and Updating Type Definition Instances In LabVIEW 2013 and earlier, when you apply changes from a type definition to instances of that type definition, LabVIEW may lose or incorrectly preserve the default values for the instances you want to update. In most cases, LabVIEW 2014 automatically preserves the default values of each instance you update from a type definition. When an instance cannot be automatically updated, LabVIEW places the instance in an unresolved
If the typedef instance is unresolved I think it would be better for the 'Review and Update from Type Def' dialog to instantly appear once the edited typedef is saved.
The typedef currently visible on the block diagram that I right clicked to edit the typedef isn't necessarily the typedef with a problem. It could be hiding anywhere on the block diagram!
I could click the broken arrow, but I would always want to sort out this problem before proceeding so this idea would make life easier...
This could be a click box in the options?
Any thoughts?
Al
