| User | Kudos |
| 15 | |
| 2 | |
| 1 | |
| 1 | |
| 1 |
This is just a small QOL thing but also not that hard to do I feel like. When right clicking a wire whose data type is a type def enum or cluster, add the option to Open Type Def. from that menu. The current way of doing that would be to right click the wire and Create -> Constant, right click the constant and Open Type Def., then delete the constant.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
