When you select several items the "right-click" functionality is available only for common operations. One of those common operations for several controls and indicators would be to set the current value to default or set the default value to the current value. Both of these are available from the menu option for multiple selections.
However, this option is removed from the right click option when multiple items are selected. Why? Simple UI configuration.
