10 | |
3 | |
2 | |
2 | |
2 |
If you have a local variable and you either rename it's control/indicator, or you click it to change it to refer to a different variable, all local instances resize based on a centre justified behaviour, which can have undesireable layout issues.
For example here is a what happens when it's made longer next to the bounds of a case structure.
(The Boolean is provided to show how it's aligned, and also to show it resized the case structure).
If the local variable were Left justified as a 'Write' type (expands to the right when changed) or Right justified when a 'Read' type (expands to the left when changed) it wouldn't make such a mess of things!
