13 | |
11 | |
3 | |
3 | |
2 |
I admit I have not sorted out all the implications of this, but here goes.
Currently numeric controls and indicators are left-aligned by default. The resulting appearance is most often undesirable since (even in the case of integers) the 1s and 10s for instances, do not align properly. We have adopted a policy of always right-aligning numerics (and fixing the number of values to the right of the decimal point) to make our displays more user friendly (cf. MS Excel) but we see many examples where developers simply use the LabVIEW default (understandably). We propose that LabVIEW right-align numeric values by default as this is appropriate for most use cases.
Available in LabVIEW NXG. All Numeric controls drop with right-justified numeric text.
