Trinity32244
Rising Edge / Falling Edge and timer delays
Status: New
Two more suggestions
There has also been a need for rising edge and falling edge triggers for boolean values instead of having to manually code this in every time.  I know this would take extra memory space but could be turned on or off maybe in the control settings dialog.
I also have to manually code in time delay functions because everything I do is in loops with parallel code.  The timers can't execute properly this way and would be nice to be able to use the built-in timing functions instead of hand-coding.
7 Comments
AristosQueue (NI)
NI Employee (retired)
Can you post a picture of the manual code so we are sure we are all talking about the same thing?
crossrulz
Knight of NI
As far as your first suggestion, look up the Boolean Crossing PtByPty VI.
wiebe@CARYA
Knight of NI
We're missing some context here...
I think this is about PtByPt functions not working in (parallel) loops?
In the loop, there's one instance, so each iteration will manipulate previous iteration's PtByPt state.
I find the PtByPt functions quite useless for this reason: if I use PtByPt in a class, it becomes impossible to use an array of it's objects...
The only solution is to give each PtByPt function an (optional) state in and state out, so we can store it in the class's private data. For now I do this manually for the PtByPt functions I find useful.
Trinity32244
Sorry for the sloppy code.  I just threw something together real quick
wiebe@CARYA
Knight of NI
PtByPt VIs would work just fine. Esp. "Boolean Crossing PtByPt.vi", maybe "Zero Crossing PtByPt.vi".
For the timer, "Elapsed Time" would do the trick.
For the magic Not Equal and Select combo, simply remove the Select (If T then T else F is a no-op)..
Trinity32244
I should have clarified but all of my functionality would be done with arrays and for-loops.  This is where I don't think any of the other solutions presented would work because it would be reset per iteration.  Unless I am missing something.
wiebe@CARYA
Knight of NI
Ok, so what is the solution you propose?
For me:
But of course you could store the state in a shift register as well...
