11 | |
9 | |
3 | |
3 | |
2 |
This function is an excellent tool for string manipulation. I suggest adding an input terminal for specifying the "row separator" string as shown. This string would default to a platform dependent EOL generated by the current function. The "delimiter (Tab)" input should also accept an empty string as suggested by others (allow empty delimiter).
