We could add a way, for example a parameter key in INI file of LabVIEW.exe, in order to run LabVIEW.exe silently, so without the splash screen and the getting started window, like a background process.
Example use case:
When you execute a build specification thanks to LabVIEWCLI (operation name: ExecuteBuildSpec, https://www.ni.com/docs/en-US/bundle/labview/page/predefined-command-line-operations.html), it runs LabVIEW.exe to complete the request. LabVIEW.exe is opened with the splashcreen and the main window. It's terrible, I want to use LabVIEWCLI to do some operation programmatically and silently (background mode) from my code/app.
