| User | Kudos |
| 18 | |
| 9 | |
| 8 | |
| 6 | |
| 4 |
I would like to see a tool in which you can actively see outgoing SQL queries as they are generated by the program.
While attempting to troubleshoot one of my programs in which I was pulling and updating data from a database, I had no way to confirm that the queries I was sending out had the correct syntax. The error message I was receiving indicated there was a syntax error, but it was a little difficult to confirm where the issue was, or if really was a syntax issue at all. Being able to see a string of the actual query would help a lot for troubleshooting programs that generate queries dynamically.
