6 | |
2 | |
2 | |
2 | |
1 |
The problem that height of local variable is 17 pix, and terminal - 16 pix, but distance between terminals in unbundle function is 15 pix.
As result - aligning to vertical compress caused steps in wires:
Right nowterminals/local variables should be slighly overlapped for "step edge free" wiring.
Please synchronize size of these icons with distance between terminals (to 16 pixels - seems to be ideal size)
Not sure if it was already in Idea Exchange or not.
Andrey.
Implemented in LabVIEW 2023 Q1.
