If you have a project under source control but haven't yet checked it out (because you wouldn't think LabVIEW would modify some attribute without telling you what it is...
), when you try to save the project allyou get is a dialog box stating you can't save it because the file is read-only.
"Project save" should trigger the same process with any VI, i.e., prompt you if you want to check the file out ot source control.
