PhilipJoeP
Scroll Bar Property for Clusters
Status: New
Add functionality/property to allow a cluster to have a scroll bar.  This way, long clusters with many elements can be shrunk down to a manageable front panel size and a scroll bar would navigate through the cluster elements.
10 Comments
crelf
Trusted Enthusiast
...for both FP clusters and BD constants!
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
PhilipJoeP
Excellent point!
PhilipJoeP
It seems as if NI doesn't give too much attention to large clsuters.  All of the problems I've had has been related to the ease of creation and use of large clusters.  This needs to be changed!
JackDunaway
Trusted Enthusiast
This suggestion ties in perfectly with my "Typedef Explosion" suggestion, and could arguably be considered a solution to my issue! Absolutely, crelf, if you apply it to the FP, put it on the BD!
tst
Knight of NI Knight of NI
Knight of NI
Or allow a tab control to be inserted in the cluster (you can't do this today). This will allow you to categorize the elements of the cluster both in the FP/BD and in the selection list for cluster elements.
The tab control itself will be a purely organizational tool. It will not be part of the control hierarchy and renaming a page or moving a control from one page to another will not require any change in the code referencing the cluster.
___________________
Try to take over the world!
tst
Knight of NI
Just to illustrate, I was thinking of something like this:
___________________
joshuatree
I kudoed this idea, but would love to see tst's idea implemented...  that would clean up alot of my "supercluster" ugliness!!!
tst
Knight of NI
I have created a related idea here - http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-clusters-to-have-quot-pages-quot/idi-p/1481862
___________________
DailyDose
Active Participant
Seriously, why has this not been implemented?  We have a cluster with a ridiculous amount of items in it.  In order to see it, I have to scroll the FP all the way to the "bottom" as opposed to just scrolling through the cluster items.  Maybe I'd like to see my other FP items and some specific cluster item at the same time.  Who knows, either way...I've got LabVIEW 2014 which can't do this...and this was suggested back in 2009...........
PalanivelThiruvenkadam
Active Participant
Hope this Feature will help a  lot in using Large Sized Cluster( Even Indexing (Cluster Order as Index Points) as like Array will also be useful)
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
