It would be very helpful if I could search for all VI's in project that uses a specific Conditional Disable symbol.
A text search for the string will find conditional disabled structures using the string:
"RUN_TIME_ENGINE==False" or "RUN_TIME_ENGINE=="
In >LV2013 (I think, at least not in 2013) you can then filter the search results on "conditional disabled structure" to get only cds's.
