Dear Devs,
the search results windows stays static when scrolling using the mouse wheel. The Block Diagram behind the Search Palettes window scrolls instead, when scrolling the wheel. One can pull the side bar on the side as another option.
I suggest to make the list of the results in the search palettes window "scrollable".
Cheers,
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
