| User | Kudos |
| 18 | |
| 6 | |
| 5 | |
| 4 | |
| 2 |
There is the option of selecting a structure to be excluded from code clean-up but having an option to select an area of code to be excluded from code clean-up would be great. For exampl, if there are multiple loops in the block diagram and you don't want to change the location or the wiring around a particular loop, I don't see there is any to do it. Event though you exclude the loop from code cleanup the surroundings and/or the location still change.
