Today, a for loop always select the minimum number of iteration between the number wired in "N" input and the size of every auto-indexed array.
It will be great to select between three mode :
- the minimum value, like today, with a "N" terminal.
- a fix value, ie the value send to the terminal, who become a "F" terminal (for example), no mater the size of the auto-indexed array.
- the maximum value, with a "M" terminal for example.
