JackDunaway
Selectable Class Data Member Scope
Status: New
Currently, a class is created with a Class Private Data Cluster. Each data member of that cluster is scoped exclusively to the owning class. For access to these data members outside class member VIs, getters and setters (accessors) must be established individually for each element. These accessors can then be scoped accordingly, allowing access to the private class data through the accessor VI, or in 2010, through an accessor Property Node.
Quite frankly, I like the IDE interface for accessing class data members using Unbundle/Bundle by Name. This feels natural for LVOOPers who have a background with clustered typedefs (which means everybody). Unfortunately, this method of data access is reserved for callers within the scope of the class data. Currently, since all class data is private, you can only use Unbundle/Bundle within Class Member VIs themselves.
I would suggest an options interface for setting the scopes of Class Data Members. Having non-private data member scopes has benefits:
  1. Obviates all the piddly accessors clogging your project tree and SCC server
  2. Allows quick visual recognition that a data member is being read/written directly (no data transformations were snuck into the accessor)
  3. Cleaner interface for callers of the class using the Bundle/Unbundle
  4. Best of all, saves considerable development and maintenance cost
Here's an example of what the Data Member Scope Configuration screen might look like:
Note that clusters can have "Custom" scope, which means the cluster's elements have different scopes. Also note that when a cluster's scope is set explicitly, it's members inherit the same scope and cannot be set (note how 'x' and 'y' are greyed under 'Center of Mass'). The default behavior (which is equivalent to today's default scope) is for 'Class Data Cluster' to be 'Private' with all descendants greyed.
This Idea is one product of a discussion which has taken several routes.
8 Comments
