| User | Kudos |
| 11 | |
| 10 | |
| 7 | |
| 5 | |
| 4 |
The clean-up feature that was introduced in LV 8.6 can sometimes do wonders, but very often it fails miserably on parts of the code...
It would be nice if it was made possible to select just an area of the diagram - or a structure (one particular case in a case structure e.g.) - and apply the clean-up algorithm only to that part.
