| User | Kudos |
| 14 | |
| 13 | |
| 9 | |
| 4 | |
| 3 |
I loved it when the feature Clt+Space , Clt+D was introduced. In fact it was jaw dropping for me when I first saw it. Smitten by the new LV version I used it extensively. But slowly I realized that it sometimes add unwanted controls and indicators too which I have to delete them manually later on. Now, I have kinda stopped using this feature.
So, it will be great if we can have selective auto-drop.
For ex.
Currently when i use this feature i get this:
Here is a new proposition:
When I move my mouse and select the subvi(s) and hit a shift key (can be any other key), it should show me all the corresponding controls and indicators in greyed out area. With the shift key still pressed I can go around and click on the controls and indicators that i want to keep. After doing that and on release of the shift key it should come back to normal
Imagine how beautiful the life would be when the same thing can be done with multiple subvis selected. Especially when you are doing DAQ/HSDIO etc programming using lower level vis.
