11 | |
8 | |
3 | |
3 | |
2 |
It should be nice to limit the action of Ctrl-B to a selected part of the block diagram.
For the moment the Ctrl-B removes all brocken wires in the complete VI.
Sometime when you have a case structure with multiple cases ... and when you have multiple brocken wires in many cases ...It is usefull to keep non visible broken wires...
The broken arrow (list of pending errors) will then help you to find all locations to modify.
