More often than not, one location doesn't work for both. Here's an idea:
This is a great idea I asked for in the 2009 beta, but it didn't make the cut.
However, this can be done in 2009 with a few tricks:
Ctrl-Space (to open quick drop)
Ctrl-SHIFT-t
violla! The control/indicator labels on the BD are automatically aligned to the left/right.
See more about this here: http://labviewartisan.blogspot.com/2009/08/write-your-own-quick-drop-keyboard.html
This is long overdue
I have asked for this for several years now and posted on the Product suggestion Center some years ag.
http://digital.ni.com/applications/psc.nsf/default?OpenForm
Consider disallowing configuration of Terminal Labels altogether: Block Diagram Terminals Improvement
