When a vi, llb or ctl is saved to the disk they can be easily identified by looking at the icons or the file extensions before opening them. But in case of a global variable it is not possible since it shares the same extension and icon as of a vi.
I do not like global variables at all, ( as i use Functional Variables), but in my present organization there are lots of Globals used (and still being used) and i find it difficult to know whether its a vi or a global.and hence this idea
Regards
Guru
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
