13 | |
11 | |
3 | |
3 | |
3 |
When running NI web server, the domain URL of the server will always redirect to the NI web server (or Systemlink) login page. Every Labview-built web application/webservice has a name and therefore must have a path (like: https://example.com/mywebapp)
I would like to be able to set a default redirect in the NI Web Server configuration to redirect the domain url to the default web application on that server.
It can probably be done in some Apache config file, but those a really managed by the NI web server configuration and are easily corrupted. My forum post about this issue has not yet been answered.
