6 | |
6 | |
3 | |
2 | |
2 |
When I use an event structure, the case I use about 99% of the time is "Value Changed". This is a bit of a pain since it is alphabetically at the bottom of the list, so I have to scroll down the list every time to select the event.
Since I suspect most people use this event the most, I would like it to be the default value when defining an event. This way, I could just select the control and be on my way!
Bruce
