13 | |
11 | |
3 | |
3 | |
3 |
As it is now, when we select a structure, we can delete it, but everything in it will be gone as well.
If we right click, we can select Remove <structure>, and that will remove the structure, but keep everything in the active frame.
This idea is quite simple: make Shift+Delete do a Remove <structure>:
As a bonus, CTRL+Delete could execute a Remove and Rewire:
