This one is more kind of a cleanup to the algorithm.
In the Front Panel to move a set of objects pressing the arrow button or Mouse drag helps. But one more option to move the objects faster according the grid size is by Holding the shift key and using the arrow key to move. When observed the pixel distance between the object changes in the last method, which is not correct. So it would be great if this is fixed in the feature versions.
To understand the issue please do the following.
Place some controls on the front panel and select all and closely observe the space between each controls.
Try to move the objects to the left or right/up or down and you can see there is no change between the objects. Now Press shift and use the arrow keys and you can observer the pixel space between some of the objects are changing.
The distance between the Chart and the color box is atleast more than 1 grid space.
Here the pixel space between the chart and the color box is less than a grid size.
I am sure this is not an optical illusion. 🙂
