When developing a supervising application, you often display information on screens of resolution very different.The main screen is often a 24''screen in 1600x900.Secondary screen are often deported screen or touch screens direct on line.But a touch screens that do not exceed 1024x768In this case, resizing the VI is not enough. It should be clear: display xx % of original size.Otherwise we must rebuild a second VI identical but smaller.
	Ingénieur d'Application / Développeur LabVIEW Certifié (CLD)
Application Engineer / LabVIEW Certified Developer (CLD)
