6 | |
2 | |
2 | |
2 | |
1 |
Did you know you can make property nodes and invoke nodes smaller by not showing the names?
Well, forget you know, it's a terrible idea to hide that information! You lose the self-documentating nature of LabVIEW. I use this as a comparison for Call Library Function Nodes (CLFN) - by default, these are dropped on the block diagram without showing names. I propose that the default is to show names for CLFNs for the sake of documentation, and so you don't have to hover over each terminal to find the one you're looking for. The biggest perk is simply the name of the function on the banner of the node. YES, there is a tradeoff between BD real estate and documentation, but I think "Names" trumps space virtually all the time.
