7 | |
6 | |
2 | |
2 | |
2 |
The Class Properties -> Item Settings is used to set the access scope. It would be comfortable if the vi's shown there in the Contents tree would show glyphs according to their access scope the same way as they do in the Project Explorer. It would be easier to identify which already have the desired access scope, especially since the Project Explorer is only updated after closing the Properties.
