I often run into this dialog, asking if I want to continue with prompts or continue without prompts when saving all. Sometimes I want to continue with prompts because I don't want to check out (Subversion) and save all of the changed files, just some of them. (I might have files with some debug changes, for example, that I don't want to save.) But it would be great if this dialog also showed a list of all VIs that need to be saved, so I know if it's only 2 more that will get a prompt, or if it's 35. Two more are okay to do a manual check out for, 35 not. Then I probably will check out a whole class or folder of classes. So please take away the guesswork of how much there is to save!
