The "Separate compiled code from source file" option is super nice for use with revision control software. However, sometimes the option to do so is not available:
This is usually because you have an express VI included somewhere in that VI's hierarchy. It would be nice to offer a means of displaying what those "conflicts" are--maybe a button to display a separate dialog, or to launch the search function with results of all the included Express VIs or any other potential conflicts. LabVIEW must know what those conflicts are--that's how it knows when to gray out the above option! So, how about a more detailed response as to why it has done so!
