6 | |
2 | |
2 | |
2 | |
1 |
Often, when modifying code, I need to reduce the size of a structure due to removing code. If I have a nested structure system (e.g. event structure in a case statement in a loop), this can get very tedious. It would be nice to have a "shrinkwrap structure" functionality on the right-click menu as a counterpoint to the autogrow. This would be an action that would reduce the structure size to something a bit bigger than the largest contents. An option to set how much extra space to include would be nice.
