10 | |
3 | |
2 | |
2 | |
2 |
Hi.
My idea is that the LED (Silver), when it has the default green colour, has like a mask where the brightness is different than when you change this default color to other.
c
It would be a good stuff that those mask be with every colours. For new versions.
Thanks.
