RTSLVU
Simple chart with time as X-Axis
Status: Declined
Any idea that has received less than 9 kudos within 9 years after posting will be automatically declined.
Charts and graphs in LabView have been driving me nuts for years. What I would like to see is a simple chart (maybe even an "Express Chart") that has a single dimensional array input and a timestamp input. Values in the array would automatically be plotted on their own plot and the time stamp would be put in the X-axis starting from the left. An option to just use the current time if no timestamp was input and amount of data displayed on the X-axis can be adjusted on the fly by setting the X-axis TIME/DIV
=== Engineer Ambiguously ===
12 Comments
Dennis_Knutson
Knight of NI
You already have the option to pass a single dimension array and timestamp. It's  just that they have to be part of a waveform data type or cluster.
JackDunaway
Trusted Enthusiast
I'm going to put my credibility on the line and say.... I had no idea you could plot arbitrary timestamps to a chart. Dennis, could you post an example? (Hence, Ravens gets Kudos too)
Dennis_Knutson
Knight of NI
There is no mention of a set of arbitrary values on the x axis in the idea and in fact, it is impossible to use a chart or graph for arbitrary values as I'm sure you are aware. I did not read this idea as applying to an XY Graph.
JackDunaway
Trusted Enthusiast
Perhaps I misunderstood this idea - I was voting for a chart that plots points with horizontal spacing accurate with respect to time, where data points could be plotted with arbitrary time spacings (think slow data collection, erratic data acquisition coming over a networked device, data collection that can be turned on and off...).
tst
Knight of NI Knight of NI
Knight of NI
Jack, it should to me like what you want is an XY chart. There's a shipping example for that (although an ugly one) and an example I posted (although an inefficient one).
I didn't understand the original idea, so I can't say how it relates to this.
___________________
Try to take over the world!
JackDunaway
Trusted Enthusiast
Yes, that's probably the best description of what I thought this idea referred to. This just seems like one of those ideas that could be useful to a large enough percentage of the customer base to justify R&D's investment... you know, written once and used by a thousand customers, rather than written by a thousand customers and used once.
I'd like to get some clarification from RTSLVU before making more assumptions.
RTSLVU
Trusted Enthusiast
I was voting for a chart that plots points with horizontal spacing accurate with respect to time, where data points could be plotted with arbitrary time spacings (think slow data collection, erratic data acquisition coming over a networked device, data collection that can be turned on and off...)."
You understand me correctly, that is exactly what I need. We have many datalogers in house that come with their own software that is simple and plots masurements on the screen. Take a look at Agilent "Benchlink" software the provide with their 34967A DAQ/Switch. My coworkers and mamagers always look at me and ask "Why can't LabView do this?"
I know LabView can do this but I have not been able to figure out how.
Dennis_Knutson
Knight of NI
Simple example. The Express XY Graph could also be used. You also need to set the X Scale properties to display time.
24336iB4DE55415DB811EA
Brian_Powell
Active Participant
Just making sure you're aware that the waveform chart honors timestamps in waveform inputs.  (I think this is what Dennis was getting at with his first post.)  Here's a snippet showing single-element waveforms.  (Ignore the issue of the timing relationship between Get Time in Seconds and the Wait; this is just for illustration.)  Note that the X-spacing is not uniform.  The same would work with multiple-element waveforms, assuming the dt in each waveform is accurate.  Also note that if time goes backwards, the chart will erase and display only the latest data.  (I think.  And by "time goes backwards", I mean if waveform N has a final time that's greater than the t0 of waveform N+1.)
24400i29ADDD96658C5D6A
24402iA3906951166D9309
donkdonk
I fully agree that one should be able to do this!
I wondered since version 3 why it was not implemented.
Didn't realise there is a simple solution as shown by Brian Powell (Thanks Brian).
Question: how can it be done if one wants a relative time scale, say X in seconds starting at 0 seconds (the start of your experiment)?
I mean a solution without having to bother with storing/managing history data yourself.
(I know the solution when using shift registers and an XY graph, but that's not what I mean).
I think it is a duplicate of this 😉
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Charts-with-quot-non-evenly-spaced-quot-timestamp-per-...
