11 | |
3 | |
2 | |
2 | |
2 |
See Also
Simulated Devices in TestStand Workspaces
Project and Workspace Context in MAX
Link to those ideas in next post
We can already create tasks, channels and scales in a LabVIEW project but, We cannot then use MAX to run those Tasks and we must use MAX to create a simulated device on a development machine. After a few projects the Max configuration becomes cluttered. Deployment and importing of the hardware configuration can get problematic to say the least!
On the other hand- if the Hardware, Data neighborhood and IVI session set-ups could be added to the project deployment would be a snap! just import the *.nce from the project without having to create one from MAX and exclude items not concerned for the project we are installing.
For integration and station troubleshooting the Sessions, Aliases, Tasks et al would be organized by application or project in MAX and fault identification has all the "tools" any repair tech could want to isolate a failure.
