I have often missed the options to set slider fill to either "Fill to zero" or "Fill to slider Index" in order to allow for easy display of certain conditions. Currently, we need to continually monitor the current state of the values and adapt the fill mode appropriately. Problem is that writing to the terminal for a value and setting the property for the fill are asynchronous. Requiring a "Defer panel update" call for something so trivial as a slider fill seems quite excessive.
Workarounds often also involve multiple overlapped (mostly transparent) sliders which is a real performance hog.
So Please give us those two fill options.. Please?
