6 | |
6 | |
3 | |
2 | |
2 |
So, having a new computer and installing the 4 versions i currently need i ofcourse missed to reinstall DaqMx after the last and most important LV install. After alot of time i managed to get hold of a disc, ofc slightly lower version so i first have to uninstall my current DaqMx ... this cost alot unnessecary time, when e.g. MAX should be able to add/complement itself to installs.
When i run the installer, it feels which versions of LV has Daq and which doesn't, it'd be great if you could add/complement Daq to LV's without having to reinstall it!
If this is best handled by MAX or some DAQ-installer i dont know, but as MAX feels like a hub it sounds logical to add some Update/Add/Attach DAQ-function to that.
/Y
