13 | |
11 | |
3 | |
3 | |
3 |
LabVIEW loops are quite flexible and allow me to do just about anything I want, but I often find myself writing the same code over and over again trying to iterate across different data types and data structures. There are several situations where smarter looping constructs could greatly simplify my code. One simple example is stepping by a delta between a minimum and maximum value. Currently, I have to calculate the number of iterations required ahead of time (for a for loop) or do a comparison with the maximum (with a while loop) and use shift registers to maintain the intermediate value. I'd like to be able to wire the max, min, and delta to my loop and have LabVIEW do the required calculations for me. The iteration terminal could also adapt to the proper data type given the input parameters. Perhaps the iteration terminal would have two outputs, one with the current iteration count and the other with the proper iteration value.
Another useful feature would be allowing me to wire a queue reference to the loop count terminal of the for loop and having it automatically pop each value from the queue and feed it to me through the iteration terminal. It would do this until there are no values left in the queue or until the code stops the loop. One could write an algorithm that pushes new points into the queue from within the loop or push the current value back onto the queue for later processing.
I'm sure there are other useful iteration strategies that are fairly common, please share them with the community.
