Oftentimes, I would rather have a smooth scrolling action rather than the line-by-line action. This is not just a whistle or bell to make UI's more modern; from a usability standpoint, it's easier visually to trace a smoothly animated object rather than a jerky object.
Here are two dorky little GIFs to illustrate the point (first is "clunky", second is "smooth"), but go ahead judge the difference yourself by opening the attached LV 8.2 VI. It contains a "simulated" smooth array using a cluster trick.
Oh yeah, this would apply to Arrays, and Trees, and Listboxes, and Clusters, Matrices, and Tables, and.... (hey, we currently have smooth scrolling for string indicators! One out of a half-dozen is a good start....)
I envision an option between clunky and smooth, because both options have their merits for different situations.
