5 | |
3 | |
3 | |
3 | |
3 |
Ever accidentally move the origin of your front panel bounds? Like shown here:
To get it back in the correct position, you need to delicately move the scrollbars or use the "drag" tool to drag the origin back into the correct place.
It'd be great if it could snap back there when you get close.
Or maybe there is a way to lock the origin or at least prevent user from scrolling beyond it?
