| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
I often find myself having to sort the rows of a 2D array based on a one of the columns. It would be nice to be able to have a native function for that. Currently I turn each row into a cluster, sort the array of clusters, then convert back to a 2D array -- way too much overhead and wiring time.
Instead, I envision something like Matlab's sortrows or Excel's expand selection.
Inputs would be a 2D array, a column index, and an ascending/descending selector. Output would be the 2D array with rows reordered such that the specified column is sorted.
