When creating a new Source Distribution to run on an RT system. It makes no sense that the "Exclude vi.lib VIs" option is checked by default. The VI will not run and cannot be launched asynchronously which is the whole point of a source distribution on an RT system.
The "New Source Distribution" wizard that creates it with default properties should look at the context it is being created and pick appropriate options. This is supposed to be a smart IDE.
