gerh
Specifying the decimal point character doesn't work with a time format string
If you try to do this ...
... the result looks like that:
You'll get the system default decimal separator, but not the defined one.
It would be great if the "Specify Decimal Point character" format sequence would work together with time format strings like %T or %<%Y/%m/%d %H:%M:%S%3u>T.
2 Comments
CMal
Active Participant
This is actually a known bug in LabVIEW that was reported in CAR 45360.  There is a discussion about it here:
http://forums.ni.com/t5/LabVIEW/Can-t-change-decimal-sign-in-timestamp-BUG/m-p/647729/highlight/true...
JordanG
NI Employee (retired)
