I often find myself switching back and forth between two VIs or two cases within a given VI to copy parts of the diagram (or check what another part of the diagram does, or for whatever other reason). In the latter case, it just dawned onto me that this is why "Word" has the Split Window and New Window functions. For those who have never used Word, this allows seeing another part of the document while working on it, either within the same window (split) or in a separate one (new) (I mostly use "New Window" as I have sufficient screen space and it is more convenient to organize).
My suggestion is to introduce a "New diagram window" feature, which allows working on the SAME VI diagram in as many windows as needed (I suppose two will be the usual number).
Any idea that has received less than 8 kudos within 8 years after posting will be automatically declined.
