10 | |
3 | |
2 | |
2 | |
2 |
The connectors hi(x) & lo(x) on the primitives for "Split Number" & "Join Numbers" do not line up with multi-connector primitives (Index Array, Build Array, Format, Format into String, Scan from String, etc). See below:
Re-opening because of a request to reconsider this functionality for LabVIEW now that LabVIEW NXG has been discontinued.
