Punjab
Stacked Sequence
Status: Declined
Flat sequence structures have been proven through usability testing to be more readable and adding this functionality would encourage more people to use stacked sequence structures.
Why we should not be able to add shift registers to stacked sequences becuase it will eliminate the break of direction of data flow due to sequence locals.
We should be able to put data to shift register in 1st frame and access it in next frame.Sequence Structure.jpg
18 Comments
Manzolli
Active Participant
How about creating a palette called "Legacy" or "Old Fashioned" with this kind of controls that will keep for extreme necessity or compatibility.
I just post a new idea here New Palette for Old Stuff
André Manzolli
Mechanical Engineer
Certified LabVIEW Developer - CLD
LabVIEW Champion
Curitiba - PR - Brazil
தமிழ்நேரம்
I think the bad part of the code is the Sequence local. If NI makes the following changes to the Sequence locals it will be a good. 1) Restrict the Sequence locals to be on the left and right borders instead of all places. 2) Keep two terminals (left and right) for each sequence Local similar to Shift Registers so that to enforce the Left to right wiring.
அன்புடன்
தமிழ் நேரம்
முதல் இந்திய ஆய்வுமெகபொப சிற்பி
சோதனைநிறுத்தம் சிற்பி
மற்ற சான்றிதழ்கள்
யாதும் ஊரே! யாவரும் கேளிர்!!
Ray.R
Knight of NI
I agree that the Stacked Sequence should be nuked..
However, for Legacy support, I would have to agree with Manzolli (and will visit his thread).
Have a hard-to-find section in the palette for old (bad) structures..
G-Money
NI Employee (retired)
Status changed to: Declined
Rick Weiß
I agree on most of the points. For those who want to use such a template to shorten their code a bit, my post in the following thread may be usefull, though:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Shift-register-for-Stacked-Sequence-Structure/idc-p/17...
DanSome
I don't need this functionality to justify using stacked sequence structures. They are one of my main tools for keeping really big programs manageable, graphically speaking. Don't take my stacked sequences away!
To the original poster Punjab: instead of shift registers, just use local variables.
Dan
crossrulz
Knight of NI
DanSome, that is the exact type of programming we are against.  Locals are not good.  Use a state machine!  It is a lot more managable and scalable.
jspinozzi
I disagree about killing this idea.  The stacked sequence is a brilliantly simple way to sequence actions without need for state machine, and it needs a shift register.  I create elegant and clean code all the time with stacked sequences and I'm fully aware of what state machines are for, and I think state machines are misused/overused in LabVIEW and take too long to implement for such simple tasks as "Do A, B, C".  In fact I think the complaint about stacked sequences is as misplaced as the point that Local/Global variables are not to be used, for example, because they can cause race conditions or because they're not memory efficient. All code structures can be misused.  For my money, both sequences and locals/globals are indisposable, and their limitations can easily be eliminated.
Please don't kill stacked (or flat) sequences, just look for ways to eliminate or prevent some of the tempting misuses people have with them both.  In fact, if everyone's aware of what those limtations are, let's fix them.  For example, stacked sequences need conditional terminals.
