10 | |
3 | |
2 | |
2 | |
2 |
It would be nice to be abble to view a case structure in Stacked mode.
This stacked structure would have one common input for the case selector.
All input wire will be automotically duplicated for each case ... and the same for outputs. (Automatic merge)
This could be a way to have a direct view to a "little" case structure ... something like a C like switch !
I would like to have a select ... but with multiple cases ...
This could have a look like this ... ( You will certainly create it smater than my example !!! )
Manu.net
