6 | |
5 | |
2 | |
2 | |
2 |
Error in terminals that are ignored/passed through by the VI without preventing normal execution should be marked differently in my opinion.
I've lost count of the times where I have to keep reading through the help files to check a function's error in behavior.
Examples: Release Semaphore, Close reference, Release Notifier
Then there're the functions that I have created that exhibit the same behaviour. People reading won't be able to tell at a glance if the error prevents execution when called from another function. As a quick fix I label the terminal 'error in (pass through)' or 'error in (ignored)', but it's not ideal.
Bonus points if this can be marked as such during development and the behaviour enforced/checked at compile time similar to the following (I know it will be difficult to reliably implement, so maybe warn instead):
