It sure would be nice if the representation of all numbers that will only be integers were all I32 (same as used for loop iteration, array index, etc.) It is annoying to me when I need to get a window size, a control width, a splitter position, an indicators bounds, etc. and then do some math with them only to find that one is I32, another is I16, then another is U32 ...... the result is lots of red coercion dots and sometimes wacky things can happen with the math if you don't convert everything to the same representation. Same thing for settings like cell positions in tables and list boxes.
