6 | |
1 | |
1 | |
1 | |
1 |
Many versions ago, we got the "static VI reference", and it made our life easier. I am suggestion a similar "static control reference" that can be tied to e.g. a strict type definition *.ctl file so we can read certain properties.
I have several type definitions that are exclusively used as diagram constants. Since there is no control in sight, I cannot use a direct property node. It would be a shame to have to place a hidden instance on the front panel just to get to the properties.
Well, we can use a static VI reference to point to the *.ctl file and start peeling until I get to the actual control (top image). However, it would be nicer if the static control reference would directly give us access to the properties of the control, such as the strings of a strictly typed enum in my case here.
With my suggestion implemented, the same code could be done as shown (bottom image)
The current way to get a static reference to a *.ctl file via a static VI reference (as described above) should be retained, because sometimes we need access to other properties.
I am suggesting a new dedicated "static control reference" that would give direct access to the properties of the actual control in the *.ctl file.
(of course some properties (e.g. value) would not make a lot of sense if used this way. Maybe there is a much eaier way, but I haven't found it).
